Whats needed for a 2g swap in a 1g?
This has been covered many many times on this site. The 2g engine DOES NOT have the spot on the front of the block to bolt the front engine mount. You will have to completely fabricate the front mount and find a place to mount it. To the block or transmission.
I have the 95 gsx ecu from the same car the motor came out of, that will work correct?
No a 2g ecu will not work in a 1g car. The links posted are for putting a 1g engine in a 2g car, not vice versa, and will in no way help you. Don't use any of that information.
depends what you have, if you have only engine then you will need tranny wires ecu and so on, if you have full engine then you just need to get engine mounts for it you don't have them.
you can find some info :
http://www.dsmtuners.com/forums/newbie-forum/278831-1g-2g-swap.html
http://www.magnusmotorsports.com/wp-content/uploads/2010/02/1gina2g.pdf
even you are doing vice versa part's list goes vice versa .
This doesn't explain anything about the front motor mount. A 6 bolt in a 2g works because the mounts are on the transmission, it doesn't work the other way around. None of this information is useful for this situation.
There is nothing helpful in that link to this situation, only a bunch of assumptions.
this thread going to end same way as that one.
looks like no one from members has fully done that or have just it's not worth explaining how to.
everything is possible this is just a matter of time and money.
The answers that were given (other than yours) were not assumptions. They are factual information to the question asked. IT is how it is, and making guesses doesn't change anything.
