What would be a fair offer for this gsx
Eagledsm
Aug 20, 2004
Norwalk, Ohio
I'm looking to get back into the dsm game again. Been looking around and shopping for another gsx. Came across one locally. Has the following mods:
fully built motor with 12,000 miles on it
Ross pistons that are .030 over
eagle rods
new head
272 cams
balance shaft eliminator
new xs power manifold
greddy type s bov
act 2100lb clutch
fidanza light weight flywheel
boost controller
boost guage
3 inch apexi exhaust
walbro 255 fuel pump
big brake upgrade dual piston calipers
steel braided brake lines with red rubber coating
new Mitsubishi struts
lowering springs
14b
Does have a problem at idle, owner says it is running rich. Also has fuel cut when i test drove it and got on it, it lost power until i let off the throttle. Dent is passenger fender and some typical paint fade on hood, but overall a really clean car. I offered 2300 - 2500 for it, does that sound like a fair offer?
Could be a good deal after you get a Adjustable fuel pressure regulator. The car is not hitting fuel cut. The power loss you feel is the car running rich. The car is running rich because it has a 255 and a stock fuel pressure regulator. Which the 255 pump is over running the stock fuel pressure regulator which also makes the car run rich.
Slight rust on the fender that has the dent from a small accident. But didn't find any anywhere else.
