What turbo do I get?!?
mandrigues
56
Jan 29, 2010
Wichita, Kansas
Hi I have a 97 Talon AWD
MODS
255 walbro fuel pump
880cc precision injectors
aermotive fuel pressure regulator
stainless steel turbo manifold
11mm spark plug wires eurideom spark plugs only
95 eprom -v3
greedy bov
3inch magen racing exhaust
ACT clutch
short shifter
aftermarket struts cant remmber
weisco pistons 8:1 rated 30psi
eagle rods H beams max hp 600
stock heads all checked by machine shop
and more but cant really remmber
I am looking for anything from 450-500hp I just need a new turbo, and I cant decide wich one to get. Max price I am willing to spend is 900$ was told to go SBR 60trim, or garret 57trim, but wont these turbos have lag? or would they be all around good, or would the evo 3 big 16g be able to handle this hp?
check out the dyno challenge section on the forums check out the turbos the guys are using in the power range of what you want and look at their mods.. that could help a little... look into the holset, turbos... they do some good work
