What Transmission's are Usable?
Mike1992
3,338
26
Jul 19, 2003
Springfield, Missouri
Im looking for a replacement transmission for my car as of now its using a transmission that came from a 90 eclipse 2.0 Nt and it grinds like a Biatch in 1/2/3 (Syncro's) What year makes and model transmissions can i use in my car? Is there a dfferent amount of splines on the shaft/crank btween years 90-94? My car has a 6-Bolt, so could I use a tranmission from a 7-Bolt? Will a 1.8 transmission work?
there wouldn't be an advantage of going with a different year transmission. Rebuild yours, synchros aren't too big of a deal.
http://www.dsmtuners.com/forums/showthread.php?s=&threadid=101950
http://www.dsmtuners.com/forums/showthread.php?s=&threadid=94361
http://www.dsmtuners.com/forums/showthread.php?s=&threadid=102795
all depends on the work you want to do. i'd rebuild it.
www.teamrip.com
www.shepracing.com
there is a lot of information in the forums regarding your question. and the search wasn't very hard.
well, the cheapest is to rebuild it yourself.
your other option are rebuild or find a used 90 tranny. not to many super cheap alternatives unless you are going to do the work yourself.
