what to get
rha2506
35
Dec 18, 2003
guymon, Oklahoma
Hey. I'm wantin to turbo my 95 rs and I don't nkow what to get. I'm lookin at a super 20G turbo ,garret t3/t4 turbo , or a mutt...I don't know which one to get or what is better for my car....the 20G is bein sold to me for 200 dollars but needs to rebuilt for about 200 dollars......i dont know the prices on any of the others..
20g will spool to slowly . Get a super 16 or evo 3 . If your still in need for huge power get the t3/t4.
First and foremost, you cannot just bolt any turbo onto a 420A without the proper manifold. HahnRaceCraft kits come with the S16G or S20G turbos. Star Performance kits come with the T3T4 turbo. Other than that, you cannot just bolt on a turbo using each manifold ( i. e. Mutt, FPgreen, red, etc etc turbos.) You have to make sure that the turbo and manifold flanges are compatible.
And NO you cannot use any turbo from a 4G63 motor with either the Hahn or Star kits.
i know y8ou can't just bolt on a turbo.....I'm goin to build up my own kit ....I just awnt to know what turbo would be the best for my 420a motor.......thanks
Well it all depends on your setup and what you want out of it. If you build your motor and accompany it with the proper fuel setup the ceiling for Hp and speed are limitless. If you want something that is good on the street and spools quickly, go for a turbo that is a bit smaller like a 16G. If you want ultimate top-end power, then look into something bigger like a t3t4 etc. It all depends on what you want outta your car.
