What to do to the 6 bolt before the swap
Mitsu_Racing
214
Dec 15, 2001
Philadelphia, Pennsylvania
I'm gonna do the 6 bolt swap on a talon i got. I plan on changing all the gaskets, main and rod bearings, all the belts, new water pump, rings, and removing the balance shaft. What else do you guys recommend i change before or after the motor goes in? Should i follow the overhaul instructions in the Haynes manual? Says it'll take 2 weeks min.
good thing i'm not a search nazi
the overhaul should be done with FSM, Haynes or Chiltons
You have to mod the block some because of using 2g parts on a 1g block.
http://www.roadraceengineering.com/2g6boltmotorinstall.htm
I wanted to know if its harder or easier than the instructions look (in another thread) but all I get are search nazi's telling me to search through 100's of threads...
Aftermarket connecting rods
Forged pistons
ARP head studs.
