what to buy?
danyz250f
631
6
Mar 13, 2005
Rexburg, Idaho
Ok, I am wondering if i should get the street slowboy front mount kit with 650cc injectors, or wheels and tires. My wheels are stock laser awd wheels (the ones that look like a spyder made them). Or do i really need the front mount right now because i only plan on running like 15lbs of boost and it is winter time here in idaho and the temerature is like between 20-30 degrees on an average day. So maybe i should just buy the injectors?:confused:
the frontmount combined with the cold winter air = more power. Bigger injectors arent nessessarily needed becuase you only plan on running 15lbs. The stock injectors are good to at least 18 with reliability. The wheels will make your car more flashy...and also look better. I would rather have a big front mount for people to see before I waste them and then they willhave to catch back up to me to find out whats done to my car. thats a better feeling than "nice rims". Its up to you, as it is your car and not mine. I have rims and my car looks about 1837987 better in the summer. good luck man!
You don't really need a fmic quite yet only running that much boost. But you soon will if you plan on turning it up, along with those injectors. I guess the question is do you want to be making more power soon, or would you rather look good first (unless you're going performance wheels and tires). Better rims (lighter) and better tires (more traction) will make any car faster and more fun to drive.
dont forget to check your local craigslist.org for good deals on wheels/tires.
so my stock injectors are good to about 18lbs with a evo 3 16g. Will i notice a difference in power with the front mount.
P.S. my car looks good from that side and because it is clean but i am in need of a paint job pretty bad. So sweet looking wheels might be like putting a thong on a fat girl.
