What size WG for 20g??
dalatinromeo
889
26
Nov 18, 2004
Fair Lawn, New Jersey
Just like the title reads, what size would be sufficient enough for a 20g? I been deciding for the last two months what turbo to pick, I have decided to go with a 20g :D .
I have been reading that most 20g's are for external WG, with some shops having the option of making internal for a higher price. But I want to go external anyway. So I was looking online to see which WG would satisfy my needs. By reading over hundreds of threads, I see alot of people are running the Tial WG; but none really said what size they have. :notgood:
My question is will a Tial 38mm WG be sufficient for a 20g running no lower then 22 psi, or to be on the safe side purchase a Tial 40mm WG?
Oh on a side note what spring I should order? I read on here that the spring you select tells you the minimal amount of boost you'll be able to run. So should I go with a a large 1.4bar(20.30 psi) or should I just go with a bit smaller spring, and control my boost with my boost controller?
Any help or input would greatly be appreciated. Thanks :thumb:
I run a tial 38 on my 20g. Its got a spring for right around 14 psi. I have run anywhere from 14 to 28 psi with no problems.
