what size/thread are these bolts.. HELP please
blcknspo0ln
DSM Wiseman
7,772
101
Jul 31, 2003
Central, New Jersey
hey,
i searched hi and lo for a picture of the return line and can't find it..i'm in need of knowing two bolt sizes. both for the oil return line on a b16G. i need to know the size of the bolt that goes on the turbo/return line and the return line / oil reservoir?? oh and i'm using the stock one that came with the t25.. help me out!
thanks,
tom
Save yourself a headache and order them from the dealership.
The B16G has the same housing as a 14B, so you can order the parts for a 1G manual, as they're the same.
Yeah, they don't show you the sizes/thread pitches because they want you to buy it from them.
But at least you have the part numbers, so when you call the dealership you can just tell them:
"I need one MDXXXXXX, and one MDXXXXXX....."
Okay, if you're looking at the Adobe Acrobat PDF files, then that won't give you the P/N's. Your DSM CD should have the CAPS software on it - if not, you can download it here.
Sure, no problem.
The model you'll want to input is D22A. Make sure you read the text files that come with it to lean how to use it, it's not the simplest program to use.
