What size injectors to go with next?
booostedGSX
296
Apr 14, 2005
White Oak, Pennsylvania
I am trying to decide what size injectors I should get for my next setup. As of now, I have 650s that are almost maxed out on an Evo III 16G. For my next setup I plan on getting a TD06 20G, FMIC, and possibly some oversized valves and BC springs.
I am not sure as to whether I should get 850s or 1000s. All mods in profile are current so you can refer to that to help me make a choice. I am leaning towards the 1000s because I have DSMLink and can get them to idle pretty well. Thanks for the help. :talon:
1000's is what I would go with and they will be more than adequate for you. They are cake to tune with DSMLink and they will take you further than the 850's if you do decide to upgrade turbos again after the 20g.
Excellent, that is exactly what I was thinking. I just needed to hear it from someone else :p :talon:
1000s are what I would go with or even bigger so that there is plenty of headroom if you decide to switch to e85.
You know, I did think about E85, but it isn't really common around my area as far as I can see. It'll still be something to think about though. I'm going to think it over for a while; I am not going to start buying parts until at least spring so I've got a good bit of time to mull it over. Thanks for the help guys. :talon:
I've always said, get the biggest injectors you can tune for. You know as well as I do once you get a 20g and get as far as you can on that you'll probably be looking for more. You'd feel rather silly if your injectors were too small for your new setup. IMHO buy big injectors once and never think about it again
