What size injectors should I get?
b00sted95gsx
31
Apr 1, 2008
long island, New York
I want to get new injectors and I just wanted to know what a good size would be.Heres some of my mods...Evo III gt 16g turbo, Greddy fmic, Apexi N1 exhaust, Injen intake, tial wastegate, greddy type rs bov, wideband, boost, and oil pressure gauges.I dont have any type of tuning tools so I will have to get one when I get injectors.
1.) What size injectors should I get?
2.) What type of tuning tool should I get?
i have pte 680's, they overflow though. Rough tunes with my safc havn't worked out too well, running pig rich. Good thing it's off the road becuase of speeding tickets, it's giving my time and money for a new tranny and dsmlink. Seriously though i'm going through this right now, go dsmlink. Why put a couple thousand into the car and cheap out on the brain, it just doesn't make sense.
1) stock 450's till you get a tuning tool.
2) I recommend DSMLink, but it is costly and especially so if you do not already have an Eeprom ECU. Else consider ECU+ as good alternative and with better features than an SAFCII. Else choose an SAFC.
with DSMLink get the largest injectors you can afford... I recommend 850's
ECU+ I believe it can ran up to 850's... though you may want to consider 750's.
SAFC 550 to 650's max.
If you want big potential then that leaves DSMLink and ECU+ as your best choices.... In my opinion.
Well if I went with anything bigger than 650's I would get dsmlink...but the question is do I really need anything bigger than 650's to reach 350awhp? I'm not trying to bench race but i dont wanna buy injectors that aren't gonna flow enough and I also dont wanna buy injectors that are gonna flow to much which means I would have to get dsmlink instead of a safc. So my question now is should I go with 650's and a safc or bigger injectors and dsmlink?
Calculate for yourself.
Crank HP = (((injector size)/10.5) * IDC) / BSFC) * 4
BSFC is a guess but I would use a range from .55 to .65. And IDC I would use 80%.
So Solving for 350 Crank HP:
350 = ((Size)/10.5) * .80) / .55) *4
Size = 650 cc/min @ .55 BSFC and 80% IDC
Size = 750 cc/min @ .65 BSFC and 80% IDC
If you assume worst case you would choose the 750's for 350 Crank HP so you have a safety margin. Because until you get the car on the Dyno you really can only guess what the BSFC is and even then it will very due to air temperature, humidity, car temperature, gasoline mixture... etc... So I think a range of potential is the best way to express it and then work with the worst case to ensure you remain in limits.
The important question is where do you want to be at the end of the day. If you ever plan on upgrading to a larger turbo, 20g/ full garret, who knows, plan for the future. I would go with bigger injectors instead of this will work for now mind set. If you plan on getting serious which usually happens after you get a taste, go with the DSM link and larger injectors, it will work for you now and later on. Just my 2 cents
I read somewhere that 650's can flow enough to make 400hp so 680's seem like they would be enough but I dont know.
Yea gonna be honest here, my first thread here was, I want an exhaust, intake filter, and BOV.
Once I got those, it never stopped. I would reccomment you deffinatly plan for the future, the injectors are usually close if not the same price for bigger injectors. I am getting DSMlink now and am very happy with my descion. Plan for the future, be safe, and you will be happy.
:D
Trust me all I want is 350awhp and I will be more than happy.Like I said I'm only 16 I don't want a extremely fast car and I'm not really the type of person that always wants more like most people.
i don't see why 650's or 680's wouldn't suffice for 350awhp? If someone can prove me wrong please feel free to do so. Also I have a SAFC-neo and a 190lph fuel pump which i no longer need since my car got totaled. Both are brand new in box.. was hoping to install this summer but thats not gonna happen.
Crank HP max from 680's:
cHP = (((680/10.5) *. 8) / .55 )* 4 = 376 hp at 80% IDC
This is on a very efficient turbo engine with a clean intake, exhaust, cams, ideal volumentric efficiency etc, etc... to get a .55 bfsc.
Crank HP min from 680's:
cHP = (((680/10.5) * .8) / .65) * 4 = 318 hp at 80% IDC
This is on a very inefficient engine.
Lets say you throw caution to the wind and run your injectors in a static mode of greater than 80% IDC of say 93%.
max Crank hp = 447 @ 93% IDC
min Crank Hp = 371 @ 93% IDC
Also yet again these ranges are for CRANK horsepower, not Wheel Horsepower. So you will need to further reduce the values to reach wheel horsepower. As I said in the previous post. If 350 WHEEL hp is your goal, your fuel delivery choice may hold you back [most likely will]. Also you will need a Walbro 255 and FPR at a minimum to reach 350 whp. And depending upon the boost level ... that may come into question ( i.e. greater than 24 psi on the Wally 255 with a rewire).
And for perspective 350 whp is roughly twice the output of the stock motor. And yes its attainable, no it is not easy and while people do reach that goal with a Evo 16G its not easily attainable as say using a 50 trim which can do it with less modifications and work. 350 whp is high goal as the engine will be making between an estimate of 400 to 415 hp at the crank.
i am not trying to dissuade you. I am trying to help you realize what it takes to reach those numbers and how to reach them and in my opinion do it safely. I don't know how efficient your engine so I can only guess the potential ranges (which I have done). The only way we can know is to put your car on a Dyno and measure it. And then it can change between each runs, it can change due to air temperature, humidity, if you raise boost it changes things... etc... etc... Its a guess till the dyno run and then its only a finite value for that dyno run. But it does give us a narrower range to work with mind you.
Best of luck. You seem set on the 680's.
  • Wanted 6 bolt NT water pipe
    • chrisman287
