what setu should i go with? 400
1g dsm d22
209
Aug 4, 2008
westminster, Colorado
k just a quick question, i just bought a awd laser, sold my fwd laser LOL. and i was wounderign what would be a realy good reasonable price setup to go with if im lookin to go at least 400 whp. and could it be doen with stock intrnals? speciffically what mods would i need? also it would be my DD.
also what things would i start buying towards my goal. like cams? fmic? etc..
my car is bone stock btw.
LOL lil turbo at 7 psi LOL.
can go up to 10 or 15 psi save on everthing stock? LOL
<a href="http://viewmorepics.myspace.com/index.cfm?fuseaction=viewImage&friendID=171356675&albumID=161788&imageID=27329656"><img src="http://hotlink.myspacecdn.com/images02/4/6469b104c0104d29971fa2311d6fae07/m.jpg" alt="" /></a>
would it harm the car in any way if i take the abs out?
You can use your stock head/block if they're in good working order to reach those goals. Cams will make it easier... and an exhaust will too.
I would say the few most important things to get are a logger, a wideband o2 sensor, and a mechanical boost gauge.
You will need some fuel upgrades most importantly to get where you're trying to go and a turbo in the 18g range... although a 16g evo3 turbo can make more than that goal in power... but it's not for everyone to try to use one that small and get a power output that's that high.
Read the upgrade path, and you'll be well upon your way, but you definitely want a logger, wideband, and boost gauge.
alright man thanks ^^, car need a lil bit f work. its got oil leaks sooo what im doin this summer is taking this thing out and doing some major gasket and seals replaces. head looks awesomely clean, bt block is filled with oil and i hate it. it also feels like it has a boost leak somewhere soo ima check all that out :) im mclovin it! LOL
  • Wanted 6 bolt NT water pipe
    • chrisman287
