what compression should I choose.
Aproductions
2,123
50
Aug 11, 2009
Allentown, Pennsylvania
Alright so I went to the machine shop today to see the progress on my motor and find out what headgasket to get.
So I am going with a Cometic MLS .020 over.
Also, I am running a Holset H1C from 20-25lbs.
Running 94oct plus the AEM meth kit 50-50.
tune= Ecuflash and evoscan.
Most important, is it safe to go with a thicker headgasket if I want to lower my compression?
here is what I am told.
if i went with the .051 regular Cometic MLS I would be at 9.6:1 compression. (I have 9:1 pistons in).
So it breaks down something like this.
.051=9.6:1
.063=9.0:1
.070=8.7:1
.075=8.6:1
and the list continues.
So for a street car that I want some bottom end on, is it safe to go with a .070 thick headgasket?...remember its MLS
I lowered my compression replacing my HG. Went mls 1.6mm though. Minus timing belt breaking after 400 miles, I'm satisfied. Only problem is I run a sleeper 16g setup and the lower compression makes boost buildup at lower rpms a little longer.
I would run 9:1 compression, Thats what I will be aiming for and if we dont get E85 here...then ill be running 93.
I will be running an hx40, but im not sure how much boost i will be running on 93...and I have dsmlink, so I dont really know what to tell you there. I never used ECUFlash and havent really been keeping up on it.
This Shoukd be in "bolt on tech" not the newbie forum. You have been on here long enough to know this and your post count shows that.
Alex, at Liquid's recommendation, I moved your thread to the Tech section, Cylinder Head and Short Block sub-forum. You'll get more high-quality, in-depth answers here than in the Newbie forum, where you'll get mostly uninformed opinions. If you feel differently, let me know.
Got me wondering what my compression is... I went with a 8:1 piston and a Mitsu 4-layer MLS, so im probably at around stock 6-bolt compression( 7.8:1 )..... Im able to run 14* peak timing at 24 psi on a E3-16g and 92oct pump gas so far ( still pushin it ), when I do 3rd gear tuning and I throttle it at 3,200 rpms I see full boost by 4k..... I've heard lower compression can handle more boost and more timing easier which is why I went with a low compression build so when it comes time to strap that monster turbo on I know I can push it.... It is a street car too, and I dont mind a little lag ;)
I guess the question is what are your HP goals and do you think you will ever run more boost or a bigger turbo? If your gonna eventually go for big power, like more than 550hp, and lots of boost, you may want to get that compression down...
I could really use some help with this.
Is .070 too thick for a mls headgasket, I don't want it to blow out.
Also would the 8.8:1 compression be okay for my car or should I go a little thicker/lower comp?
If you always plan to use pump/meth, 9:1 is fine.
If you want to run decent boost and have the option to do so on pump alone, get under 8.5 so you can keep some timing in it and make good power.
I run 30psi with straight 93 pump gas on a .066 Cometic MLS with no issues. Overall compression is about 8.3 in my setup. I never had a problem with the .066 HG i've been using. I kicked the snot out of the car on the dyno without even re-torquing the head, no issues.
I wouldn't hesitate at all to run a .070 MLS.
thanks man,
I think I will go with the .070 gasket...giving me about 8.8:1 comp.
so I will run about 25lbs with 94 and 50/50 meth.
I know I could do 9:1 but I want more flexibility. I also found a .080 gasket but that is getting thicker and my comp would be like 8.3:1 or something.
the machinist told me to do 8.6:1 which would be a .075 gasket.....would that give me that much more timing and boost?
thanks man,
You're not going to see much difference between 8.6 and 8.8. Higher compression is good for off boost power and MPG, so with the higher octane from meth i'd go for the higher side, the 8.8.
well from what I hear the h1c doesn't start flowing alot till 25psi.
You sure can boost to what ever you desire, long as you have bottom end support, like me, i have eagle rod, and wiseco pistons. good to handle that much or more. and with E85, it will handle 25psi with ease.
But even with 6bolt rod, i am sure there will be no problems. just look at the guy that did 6++hp on a stock 6 bolt. oyster motorsport i think with E85.
