what PSI for boost leak tests?
1Gina2G
810
May 6, 2011
Beaufort, South Carolina
I've researched this, but i've only see people talk about having it at the pressure you're running. I think I'm going to be running 9 since the WG lines connected to the intercooler piping.
What pressure should I set the air compressor to? it'd seem like 9-30 psi is a little low for testing..what's recomended?
I usually shoot for around 30 psi, some people go for around 5 psi more than what you will be making. Either will work, just make sure to pressurize it to a higher psi than what you will be running.
I always do 20 psi or 10 more than I plan to run in a car which ever is higher. My old EVO I tested to 40, my Conquest will be tested to 20 since I will not be running more than 10 psi of boost on the stock 12a turbo.
Keith
I'll test with 30 psi it looks like.
while on the subject of BLT's, does it matter where exactly you are on timing? I was getting mixed ideas while reading earlier posts.
some say to line up the timing marks but I can't tell if its plus or minus some timing, for the valve overlap. Does it matter? :confused:
