What o2 sensor do i need to replace?
videogamemaster
129
May 28, 2008
Peyton, Colorado
So I went to checker auto parts today to buy a new o2 sensor to hopefully help my gas mileage... Well from what I had heard i need to replace the one that connects on the left side of the engine, then runs right over the heat shield, and then looks as if it connects in on the lower right side of the engine.
So he looks up the parts and has upstream and downstream sensors... He claimed that i needed an upstream so I thought sure. I take it out to my car and it is nowhere near long enough. So I go back inside and he says replacing the o2 sensor i was trying to replace will help in no way at all. He said that I need to replace an o2 sensor that is right on top of then engine WTF
I am really confused so could someone maybe get some pics of the o2 sensor i need to replace to help with my gas mileage?
Is the o2 sensor broken? If not changing it won't really do anything. Upstream o2 sensor is located on the o2 housing right after the hot side of the turbocharger. Second one is farther down your exhaust pipes near the end of the downpipe depending which down pipe you have. The o2 sensor on the o2 housing is usually the most important. Most people down use the one on the downpipe. Note both of them are in your exhaust streams and not located on the engine.
This should help you on the one your looking for.
Its at the very bottom right of the photo:
<a href="http://imageshack.us"><img src="http://img257.imageshack.us/img257/7027/1000782tk2.jpg" border="0" alt="Image Hosted by ImageShack.us"/></a>
The other one located after the cat is just to make sure it is working properly.
:dsm:
  • For sale 2g 2G Clear Tail Light Set
    2G Clear Tail Light Set $550 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 98 GS-T for sale
    Here is my 4g63 7bolt fully built for sale
    • Yahdin2G
  • Wanted 4G63 Mpi relay
    Looking for a 95 eclipse gst mpi relay
    • SquatchinGST
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
