what is the difference between in fwd turbo transmission and a non turbo fwd on 4g36
Luis77321
Feb 2, 2011
Cleveland, Ohio
what is the difference between in fwd turbo transmission and a non turbo fwd on 4g36?
The front wheel drive turbo motor is a 4g63. The front wheel drive non-turbo motor is a 420a. 2 completely different motors and 2 completely different transmissions. The bell housing on the transmission of a 4g63 motor bolts to the left side of the motor. The non-turbo transmission bolts to the right side of the 420a motor. That being said, the transmissions bolt up in a completely different way, and on opposite sides of the engine bay.
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
    • ist dwa
  • Wanted ISO Extreme Psi weighted shift knob
    Easy peazy…
    • James92
  • For sale 1g 91-94 ignition coil
    1g coil with harness side igniter harness. Digging in a box of remains from a yard six bolt for...
