what injectors? 650s?
DSMjrv
352
Dec 29, 2004
corona, California
okay my six bolt is a little built, and ive got all the basic bolt ons... 3" RSR turbo back w/ported 02 housing, b16g with ported exh manifold, supra fuel pump, greddy FMIC and BOV, greddy electronic boost controller, custom 2700 clutch, lightened flywheel and crank, dsmlink although i havent tuned anything yet... now i need injectors.... i wanna basicly be able to safely run 20 psi which is about 300whp right? what injectors will i need? is there anything else?
^ exactly.... and with DSMLink you can compensate for huge injectors like 850's. If you are planning on staying at 300hp then the 650's should be fine, if you think you might want to keep going where the sky could be the limit then you can go even higher.
I have 850's on my EVO 16G setup and it's running great. A bigger turbo is in the works next year and I needed injectors now, so I went big.
