what gets grounded for the timing light
1Gina2G
810
May 6, 2011
Beaufort, South Carolina
For a 2G, what has to get grounded on the car to let the ECU know it's hooked uo to the timing light? I only saw the explanations for 1G's, is it just any grounding connection next to the battery?
I'm slightly confused on what to adjust the gun to, its an advance light and the turning knob numbers from 0-70
What type, Style of timing gun do you have?
But, i'll provide you with a General answer.
Set up
1. Red goes to Positive post on battery
2. Black goes to an "engine ground",pretty much any exposed metal tab on the engine.
3. The Clamp to the #1 spark plug wire.
The knob gives an accurate measurement of the Timing buy reading whether it's advanced/retarded, and by how much.
How to use the Knob.
1. Look at the timing marks, turn the knob til it lines up at 0 on the marks on the Timing cover. TDC)
2. Look at the gun, write down the number the knob is pointed at.
that's where your timing is currently at.
for example, light shows 0, but knob shows 3. your timing is set@ 3 degrees.
The Ecu can compensate timing, so when attempting to adjust your timing some cars require pins to be jumped, or an engine connector disconnected in order to do it correctly.
Since this is a general answer see your cars' repair manual for instructions on how to do this.
It's an Actron CP7528 advanced timing light. Actron®
This is what I was mostly trying to figure out. I have the haynes & chiltons manuals but I can't identify aything in the black & white pics, I did notice it said to insert a paperclip into one of the open connectors on the firewall, but there's actually quite a few open connectors, it's to vague for me.
I'm also assuming if this connectors not grounded when the timing lights setup, you can't adjust the timing with the CAS on the head either, correct?
sorry guys, the pic didn't load for me the first time when I refreshed the page so I completely missed the posted pics. Much appreciated, I'll have to compare tomorow in the day, but I honestly don't remember that brown connector or even that blue one anywhere in my engine bay, but I reconize the black one, there was a cupple of the black ones and a white one that all looked really similar, I'll have to post pics tomorow.
But if they were cut out for some reason, I can ground the pin in the ECU? does that mean pin 52 is empty without a fuse? or do you just take the fuse out and insert a paperclip?
