blkdudeinaz
- 31
- 0
- Jan 25, 2007
glendale,
Arizona
RRE Engine 20 over, 95 pistons, 91 rods, hks cams 264
272, 550 cc injectors, 190lph fuel pump with hard
wire, extrude honed intake and exhaust, Ported head,
34mm tial wastegate,VPC, SAFC, ACT 2600lb clutch, RRE
lightened flywheel, rebuilt tranny with steel shift
forks/double synchros, welded center diff, transfer
case from 94, FP 7cm green, Buschur Front mount, 2.5'
inch press bent exhaust, test pipe, 2.5 down pipe,
EGT/Boost/Oil pressure gauges, Big brake upgrade,
Fluidyne radiator, colder range plugs.
Ok that's what I have what else should I get any suggestions
