What ECU can i use in my car?
805eclipse
159
Jul 16, 2003
Newbury Park, California
ok i have diagnosed that i have a bad ecu after having to spark and the car not being able to start.. i want to know what kind of ecu i can replace mine with. I have a 91 FWD 5 speed from california.
can i replace it with any ecu 91-94 or just FWD 5 speed? and does it need to be a CA emmisions ecu or not? i need to know asap so i can order one thanks alot.
Most likely you will have to use the California model. However, if one is available, try it and see what happens. I've used auto pcm's in manual trans eclipses and they worked ok as far as I coud tell. California has much higher emissions standards than the rest of the country hence California car.
Good Luck
The only thing that matters is that you get the ecu with the CA emissions control on it and that it is for a 1g dsm. Out side of that it doesn't make any difference. I would get the Eprong though. It is worth it. One other thing, when you put it in and start it up, it will run bad for a few mins and then it will be fine. The ecu just has to set itself for your engine. Hope that helps.
