What do you think about my setup??? 11 Sec???
Status
Not open for further replies.
91orangeGST
193
May 25, 2004
Winfield, Missouri
I've finalized my setup for my 91 TSI and have already purchased about 75% of the parts on my list, but you guys tell me what you think.... Also what you think I can get out of this... Any suggestions will help!
ENGINE
.20 over Wiseco pistons and rings.. gapped bigger....
1g rods
Clevitte 77 bearings
Cometic HP head gasket
ARP STUDS.... head, rod, main.
Ported and polished head.
HKS 272/272 Cams (not sure about getting yet)
FUEL
Walbro 255 pump....Rewired.
750 Injectors
Afpr
MISC
K&N cold air intake
Cyclone Intake manifold (found in perfect condition at a junk yard with coil pack for 50.00)
24x12x3 FMIC W/ 3IN piping
HKS bov
Turbo back 3" exhaust
8.5mm magna core wires
NGK plugs
ACT 2600 clutch
Findeza 8.5lbs flywheel.
Tubular man... External waste gate
TURBO
T3/T4 50 Trim turbo... Externally gated.. Boosting at 24PSI...
tuning
DSMLINK
Dont know what tires yet :(
Also all the little gages.... :p
With good tuning and on pump(93) or race(110) gas what do you guys think a reasonable goal for 1/4 and hp would be???
Thanks,
Wow its threads like these that reminds me why I went to sddsm.org. Stop lying you havent bough 75% of sh1t, cause if you did you would have put up pictures. You aint got to lie to kick it. Have fun with your car and quite lying to people. You want an 11sec car. Thats easy with money, and easy without all the big name shit. You dont need a hks bov or dsmlink or a damn cyclone intake mani. or tubular exhaust mani. Stay with stock mani's and 1g bov with dodgegarage mod then get a b16g(570) bolt it up get some 720's(350-400) a safc(used 200) a mbc(50) exhaust (varies diy=+or-150, buy name brand sh1t=9,999,999) Do all of that get a good tune and you can run 12's. Turn up the boost , get a wideband and tune like a maniac and you can run high 11's. Its been done down here in deigo time and again. Stop being a noob and posting dumb wish lists for santa this year and get to buisness. By the way go research sddsm.org :dsm:
What is your problem? If you are like this all the time< I feel sorry for your family and friends.
Anyway, I think the setup is good, I don't see an intercooler or fuel pump on there. Yes you will need a clutch, and maybe a whole tranny if you have the money. And about the cyclone manifold, I have heard it doesn't work on DSM's without some fitting problems, so... good luck :thumb:
With all that listed, you should be in the 11's no problem and around 400+ whp.
Its going to cost you ALOT of money and you will most likely need a new or rebuilt trans if the one you have isnt in good shape. BTW ive ran 11.8 at 119 so I know what it takes to do it. You might want to think about upgraded fuel lines and a good afpr (an aeromotive a1000 works nicely) You wont need an upgraded intake or exhaust manifold either. If you want to tune easily and alot more precise than a POS SAFC (sorry guys, I hate those things), then get a wideband and DSMLink. You will never look back. A wideband is a MUST if you ask me
Bench racing and a wishlist. Awesome.
The parts guide we have here is pretty comprehensive,as is the search feature when utilized.
gSx_r1der: :rolleyes: :toobad:
Status
