What can i tee on the IM?
lars y
141
Oct 11, 2007
Halden, Europe
I have four nipples on the intake manifold, and i have five things that need to be connected to it.
Its a BOV, MAP-Sensor, catch can, power brakes and the fuel pressure regulator.
Wich two can i tee together to the same nipple without making trouble?
Thanks
Oh, ive heard i shouldnt "T" into the MAP line, since it needs to know exactly what the pressure in the IM is.
Im not running with the emissions system or the stock IM.
I was going to "T" the BOV and the AFPR together, as the AFPR is just a membrane so it shouldnt be messing too much for the BOV?
It will make a difference, don't do it. Keep the BOV on it's own designated signal.
Thanks for the clarification on what you want to do.
I'd say your best bet is to tie the FPR & MAP together. The brake booster line would be kinda tough to T into, since you would need a specific adapter/reducer and the catch can ...well it's dirty.
FYI The most common place to add a MAP sensor for a boost gauge has been the FPR line for a while now. Make sure to boost leak test the system afterwards
I have my FPR and BOV line into a T because I only have 3 ports on my intake manifold, and I'm using the other two for brake booster and PCV. I had it separate before and now together, it makes absolutely no difference. BOV goes off exactly as it did before under the same pressure.
Alright, thanks guys!
I will tee the FPR and MAP together, it seems most people recommend that.
I`m making everything from scratch here so its no more work for me to do that.
By the way, i was told i really shouldn`t tee anything into the break booster as it will 'chug' in a lot of air when i hit the break pedal.
