what bolts to hold enegine on engine stand ?
Shawntosseth
Mar 18, 2016
Bismarck, North Dakota
4 m10x1.25mm x80 is what people on here seem to be doing. If you're not sure, take one of the bolts from the bell housing to block and take it to a hardware store and say you need the same type of bolt but long enough for your specific engine stand.
Measure the depth of thread used in the block, and add that to the depth of the arms on the engine stand. Chances are you will also need to stack some washers to act as spacers.
