What are the symptoms of a cracked head or block??
1G90AWDTsi
272
Jul 7, 2007
southern, California
Guys, I check the forums for "cracked blocks" and it seems like no one really pin pointed what the symptoms are...do I got one?? I have coolant in the oil without a doubt. My car starts up...no funny noises...full oil pressure...good power...no visible leaks. New block as of 2006 with lots of modding. What are the symptoms of a cracked head or block??
yes the head was port/polished 3 angle VJ. It was all done in 2006 and I didn't over heat the motor. It just happened...i let the car sit all winter and every week I go out and start it to circulate the fluids...last week it was fine, this week it wasn't. It has a comedic HG too as of may 2007
Im still guessing it has something to do with your HG, did they torque the head right? If the block was cracked you would probably be losing compression.. wisemen would be a lot of help right now..:)
My money would be on either-
Headgasket leak, when the head was torqued the bolts need to be lubed, otherwise you need to add about 5-10 ft-lbs. Also Copper spray gasket is helpful sometimes.
Turbo leak, if you have a water cooled turbo, your center section may have a crack in it, and this can introduce coolant to your oil through the shaft journals.
Oil cooler leak, this shouldn't be a problem, as you have a 90, and most 90 models have air to oil coolers. If you have a mitsu water to oil cooler, if you have ever overtightened the oil filter, this can cause a leak into the oil system.
Most likely a headgasket, but in any case DON"T drive the car. Antifreeze reduces the lubrication capacity of oil to that of sandpaper.
wow, thanks for the advice...is it ok to start it up in order to move it when snow trucks come in to plow???? otherwsie they threaten to tow it. It'd only run for a quick minute just to relocate for snow removal.
  • For sale 2g 2G Driver Side & Manual Trans Mount with Poly Inserts
    2G Driver Side & Manual Trans Mount with Poly Inserts $70 + shipping & paypal feesYou must be...
  • For sale 2g 2G Dejon Tool Upper IC Pipes
    2G Dejon Tool Upper IC Pipes $80 + shipping & paypal fees* throttle body flange looks brand...
  • For sale 4G63 Cometic 86mm Head Gasket
    Cometic 86mm Head Gasket $70 + shipping & paypal fees.051 MLSYou must be registered to see...
  • Wanted 1g Looking for 1g interior
    Wanting to buy driver side a pillar interior (with pods preferred), both interior b pillars...
    • Walnuts
  • For sale 4G63 Ebay T3/T4 TO4E Turbo & Manifold
    Ebay T3/T4 TO4E Turbo & Manifold $100 + shipping & paypal feesYou must be registered to see...
