What Are the Symptoms of Crank walk?
DSM GREENHORN
Banned Member
21
Mar 23, 2005
Bellingham, Washington
My car was running fine, and then all of a sudden it starts shuddering really bad when I take off from a start. It feels like I'm letting the clutch out too fast, but that's not it. It still does it when I ride the clutch. Right before this happened, I accidently turned my boost up to 16psi on my b16g on a stock motor w/ stock injectors, and stock fuel pump. I do have an S-AFC, but it's @ 0's on all the throttle settingd (high and low). When I had the boost up that high, it was making a sound that sounded like paper ripping when I really got on it. I only had the boost like this for about 5 mile, and then turned it back down to 10. I know it take a lot of boost to get crank walk, but could it have messed up my crankshaft just a little. It also vibrates a bit under heavy acceleration. Does anyone have any ideas on what this could be? Is it my clutch? I have a centerforce that's pretty new, but I know things can go wrong at any time. Please help me understand what I need to do to fix this. Oh yeah, one more thing, I just changed out some vaccuum lines right before I took off, would this have anything to do w/ it? Thank-you to anyone who finds it in their hearts to answer my probably stupid questions.
probably not crank walk. Overboosting is not going to mess up your crank. If you replaced vacuum lines recently that would be the first place I would look. Other than that I think its pretty hard to diagnose with the info you provided.
  • For sale 2g 2G Driver Side & Manual Trans Mount with Poly Inserts
    2G Driver Side & Manual Trans Mount with Poly Inserts $70 + shipping & paypal feesYou must be...
  • For sale 2g 2G Dejon Tool Upper IC Pipes
    2G Dejon Tool Upper IC Pipes $80 + shipping & paypal fees* throttle body flange looks brand...
  • For sale 4G63 Cometic 86mm Head Gasket
    Cometic 86mm Head Gasket $70 + shipping & paypal fees.051 MLSYou must be registered to see...
  • Wanted 1g Looking for 1g interior
    Wanting to buy driver side a pillar interior (with pods preferred), both interior b pillars...
    • Walnuts
  • For sale 4G63 Ebay T3/T4 TO4E Turbo & Manifold
    Ebay T3/T4 TO4E Turbo & Manifold $100 + shipping & paypal feesYou must be registered to see...
