what all is needed to install a act2100
95GST2841
114
Feb 11, 2006
Palm Harbor, Florida
what all do I need to install a ACT2100?
what does labor normally cost for this?
somebody told me they had a relatively new one off of a EVO3???
clutch and disc for 200$ is this a decent deal?
There are a couple great tech articles on this. The only specials tools you need are a tie rod seperator and the clutch alignment tool.
I'll be installing an ACT2600 and a streetlite flywheel tomorrow.
For the record, you don't even need a tie rod separator (pitman puller). Just tap the part the tie rod connects to with a hammer, it should just fall out, and you won't rip the boot. On the other hand, if the guy above ment a pickle fork, then yes, you'll probably need one for the ball joints. I still haven't successfully used one without ripping boots. I hate those things.
labor should cost about 250bucks if you take it to a shop.If you buddy is helping you get him a 12 and 50bucks
  • Wanted 6 bolt NT water pipe
    • chrisman287
