Weird problem at 5000 RPM
IWANTSPEED90DSM
83
Jul 27, 2002
It seems that no matter how much boost i am running, if @ WOT the car will cut out at about 5000RPM. In 1st gear it's VERY violent. The car just stops accelerating REALLY hard. As if it's hitting a fuel cut.
In 2-4th gear, after 5000 RPM it makes a rev limiter type sound, but doesnt completely cut out like it does in first gear. It also takes a LONG time to build boost, despite only having the 14B.
Car=
93 TSi AWD Converted to 6 Bolt
ACT2600LB clutch
HKS 272 cams
Stock Turbo @ 15PSI
Full 3" Exhaust
I'm having the same problem and I think I've narowed it down to a few posiblitys. At 15psi, you guys should be running higher pressure injectors. You might be getting a sort of fuel cut. The other thing is I find my timming is now advanceing corectly. Are you guys throwing code?
