2G Weird idle
Dawson159
5+ Year Contributor
157
16
Nov 13, 2017
Billings, Montana
so here’s the deal,
Whenever I start my eclipse it idles really bad and almost stalls until about 5-10 minutes later the idle jumps and idles regular. I can’t drive it until the idle spikes so it sucks.
I’ve researched it a bit and it seems that what I need to do is block my FIAV. I found a thread on how to block so should I do that? Is that what’s mostly likely gonna fix it?
The only reason I’m asking is I want to daily drive it and I live in Montana so it gets cold and it makes it hard to cold start but I have another car I can drive if it gets too cold
I have a FIAV bypass. I live in Washington state. It’s 30 degrees and lower now. Car starts fine, idles at 1200-1300 and then settles down to 750+- when at operating temp.
Ok I’m going to order a bypass plate instead
O
If you do decide to do a fiav plate do a bypass not block off or you will have idle issues ask me how i know LOL
ok I’ll do the bypass instead
Doesn't sound like a FIAV problem to me, more like it's not firing on all cylinders for awhile. Is that possible?
I don’t think so because it idles and drives fine after ~5 minutes
Have you played with the biss screw without a good reason to? My car did that when i fixed the ecu previous owner just played with it insted of doing it correctly trying to fix a high idle. He left it all the way in so and the car wanted to serge and die.
I haven’t messed with it but the previous owner could have is there a way I can check?
And during those 5 mins or so when it's not idling fine, is it firing on all cylinders or half?
Now that u say that it does act like a misfire because when I drove it it had no power and won’t get over 2k rpms and wants to die. But how can it suddenly start running fine after 5 minutes?
Did you buy a good brand? I have seen brand new NGK out of the box cause a misfire that went away upon putting used oem back on the car.
They are NGKs but I ran a timing light test and they are all firing correctly. I’m still confused on how that could cause it and suddenly be fine and drivable after 5 minutes.
Could there be something wrong with my coolant temp sensor or something that has to do with that?
