weird idle help!
96eclipsegsx56
147
Mar 11, 2011
lowellville, Ohio
Ok so today I flushed out my radiator and cleaned my throttle body with carb cleaner and now while idling it bounces from 1000-1700 and sometimes sits at 1500...did I ruin my iacv? Or what could this be?
No Idea on the popping noise, probably a backfire due to the carb cleaner in the system? It sounds like a bad ISC. Read the FAQs and see if that helps! Good luck
ok so today i went to see what i can do to fix it and i started with the biss as stated and while the car was running i decided to check for vacuum leaks...i had one between my tb elbow and tb...i fixed that leak and tightened biss and car idles fine!!
oh and Thank You all for the help!
