weird boost problem
noss88
98
Feb 20, 2009
Bayarea, California
So sometimes when i'm driving, the car will sometimes boost normally, then sometimes it would sound like the shaft of the turbo is hitting the side of the turbo. I pulled out the intake to check for shaft play, the turbo was a rebuilt 14b and i only put ~3000 miles on it and it has a tiny bit play up and down left and right, what could've caused this? a bad turbo rebuild? i already picked up another used turbo with 0 shaft play, should i just go ahead and get the turbo replaced?
Go ahead and put the used one on, a bad rebuild could cause it.
I thought a (small amount of) little up, down, left, right was ok. In and out is what kills.
When the turbo is being oiled the movement is taken care of.
