web cams 546/547
dj-t
197
Nov 30, 2010
Sacramento, California
Found these guys while cleaning up the garage. My bro got these in the Fast and Furious years but never installed them before selling the car. So he never knew how they were.
Never was really planning to upgrade cams but since I have a set here, why not? I search and it seems like these cams are not really used because of the idle. But, most of the threads are from around 2002.
For folks who have experience the WEB CAMS what are your impressions on them? Compared the the popular comparable cams these days would you still use them? Why?
Web Cams got a bad rep because they quality was well garbage. Best bet is to have them tested for run out, mag'd, and correct (and matching!) lobe grind before even thinking of using them.
That's pretty much what I have found when i was looking for info on these cams. But, there was a few that never had any problems with these. Valve spring pressure to high maybe:idontknow:
im running a set they work fine ... bolt them up and go fast.
How long have you had them in the vehicle? What are your impressions on them from what you had before? What kind of gains did you get from them? Have you inspected the cams to see if the cams wear out like a lot folk says? Do you use it as a DD? If so, how are they in everyday stop and go traffic?
they are abit aggressive Ive had them for around 4yrs i don't know what ppl are saying but the build quality is solid. Ive looked at them a few times look fine. i love them they work fine. if you have them put them on. Ive driven the car on a daily and long trips. but if you want to sell them go for it. Ive kept mine because they haven't broken they do the job and it's allot different than with no cams.
dsm gods don't strike me down this is just my experience with these cams.
i also plan to use these when i swap over to E 85.
I have a set in my car, and I have had no issue with them. They sound nice, but can't say I have any numbers to associate with them, as the car has not undergone any dyno time, and barely any seat time.
