2G Weak spark in 2 cylinders
AlexGsxCummins
395
38
May 31, 2014
Bremerton, Washington
Okay so I know normally, it would be obvious that a coil is going out but it's 1 off of each coil. The left picture, it's number 3 and 1. Now before I go testing everything I was wondering if with having no cas because it's a 95 motor, and the p.o put a evo 3 coil pack on it could that for some reason cause this issue or should I go test it?
Thanks ill start with the coil, I didnt want to start testing a bunch of stuff it something I had on the car doesn't quite like to "play" with each other. So ill test the coils next, I almost want to just replace them but ill see how the test comes out
