wb02 or MAP
brute
1,551
48
Jun 29, 2005
Rio Rancho, New Mexico
Hey guys I have a 3" GM MAF but no translator. I'm not in a hurry to hook it up, I just want to get my car running. In the next couple weeks, I hope to have it running, then I'll buy DSM Link.
My question is, with DSM Link and the GM MAF, what is better to tune with: a wideband 02 sensor or a 3 bar MAP? Also, is one easier to install or cheaper? What route should I go?
lokmeup from the DSMlink forums (who made the tuning guides) states the athe WB route is a more constiant way of tuning in this thread: http://www.dsmlink.com/forums/showthread.php?t=4711&highlight=tuning+wideband PS until you purchase DMSlink you will not be able to view this thread I linked so I copied the post here:
I find the WBO2 AFR to be much more consistent with this method of tuning.
I never experience any bogging between shift with the tuning using the WBO2. The only problem I had before the new method was the nasty little lean bump in AFR around 3500rpms. That was annoying to try to tune out with the WBO2 tuning method.
I used the boost source to retune the MAFt because I did not have accurate airflow readings and wanted my logs to correctly represent the car. As a plus, after getting the airflow readings accurate, my injector duty cycle went down.
Ron
I like the WB method as well.
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 1g 1990 Turbo Throttle Body ( rebuilt )
    1990 Turbo Throttle Body $85 shipping & paypal fees* this throttle has been rebuilt and is in...
