DropSomeMoney
- 84
- 1
- Feb 15, 2013
Rockford,
Illinois
Ok. I've read a lot of post on here as well as other sites about this. But I just haven't been able to come up with a clear answer since what I've read is not the same as my issue. So I'm going to start with the coolant temp thermostat today and then the water pump if needed. Using the process of elimination I guess.
Here are my issues: the first thing that made me believe I was overheating is that I saw some steam coming from the radiator. The head was extremely hot. But when I went and looked at my factory temp gauge (which seems to work ok) it was showing the needle right in the middle. Since then I haven't ran it more then 4 miles. All I do is go pick my daughter up from school. And after I get home from picking her up a feel the engine and it seems hot also(yes I know the engine is suppose to be hot). After this I have strarted my car up and let it get to operating temp and took the radiator cap off and it seemed to be not pumping the coolant through the hoses. Coolant fluid never went down. My radiator fan used to kick on and now they don't. So I'm thinking its either one of the two.
List of problems again :
1) getting very hot
2) stock temp gauge showing ok
3) radiator fan not kicking on anymore
4) coolant not showing flow
My question is... Does the ECU run off the thermostat witch may kick on the fans or maybe even the pump. I know the pump runs off of the accessories belt. But I'm not good with how computers operate so I was thinking "I wouldn't doubt it".
Thanks
1) getting very hot
Thanks
