Water pump pipe differences
chrysler kid
3,552
1,150
Dec 20, 2002
Mckinney, Texas
So I re did the head on a gst with an eBay 16g turbo
I'm comparing my 96 gst to the 98 which has the improved block design and black box ecu
My question
The cylinder head is getting hot much too quickly on the 98. It will boil out of the cap when I try to purge the system with the cap off
The coolant pipe is different on the 98. The water tube nipple is pointing downwards on the pipe, and the block fitting for the turbo coolant feed is facing the oil filter housing
On my 96 the water pump tube has a feed line directly before the oil feed, the 98 points down ward.
I believe the 98 has a water pump tube from a 1st gen eclipse, but I need info from some one who might know the difference
This is how it should look, the first tube in green going to the turbo is missing on my 98, it is pointing downwards on it now
If it points downward and connects directly to the lower rad hose, it's a 1G water pipe and thermostat housing. If it points upward and mates with a rubber oring to the thermostat housing it's a 2g configuration.
The coolant pipe that runs under the exhaust manifold, from the water pump, that connects to the thermostat housing on the head.
Also the coolant port on the block under the large water pipe from the pump to the thermostat housing
I believe I found the answer, the automatic cars had the coolant pipe at the bottom which fed the turbo, and the coolant port from the block would vent into the oil filter housing.
At least, that is what I assume since extreme psi lists two different t25 coolant lines (manual/automatic). Also I've found other images of 2g cars with the same water pipe design and block water outlet
The only water pipe for 2G turbo cars is MD306269, no difference between automatics and manuals. To that point, there is no variation in coolant pipes at all in or around the turbo in regards to transmission. The diagram above is the end-all-be-all OEM diagram for 2G turbo cars.
ExtremePSI shows (3x) joints for coolant:
  • coolant feed at block
  • coolant feed at turbo
  • coolant return at turbo
The water pipe has (2x) returns built into it and the other feed is at the thermostat housing.
The pipe itself points upwards to meet with the thermostat housing. I replaced the o ring to the thermostat housing a few days ago
Yeah I get that. It's not like I or anyone else would weld a new tab onto the water pipe. There appears to be 2 different styles of water pipes, one with a feed directly under the o ring for the turbo, another style with a feed at the bottom of the pipe before the bend upwards to the housing. See picture below
http://www.dsmtuners.com/threads/water-pipe-block-off.378988/
When your coolant boils over with the cap off, is your heat on? Heat needs to be on
Heater is on, cap is off. Possible problem with a coolant feed line to the turbo is showing severe calcification and boiling coolant out of the fitting at the turbo. Not as much of a leak as it is a coolant ooze out of the fitting. I have removed exhaust manifold to inspect turbo for signs of oil seal failure and found valve seal failure
