water leak problem(inside the car)
LTUDSM
1,802
7
Jun 27, 2005
Morrisville, Pennsylvania
I noticed that after rainy day my driver side floor mats front and rear are gettin wet. So a day after i saw a water run marks commin out of my speaker grill. So what it would cause this kind of a leak? weather stripping around the door is in a good condition. The only bad thing that i have-3 or 4 Tinny holes on a door for a sideskirt clips.
has your windsheild ever been replaced. ive had problems with the subarus leaking there (im a subbi tech). then i would check to make sure your window is going all the way up and meeting the rubber
Water is tricky. It can leak in from one spot and drip on the opposite side. But i also have the water coming from the speaker grill. Hopefully someone who has fixed this chimes in.
the floor pan has plugs in them, if they are removed or have fell off water will work its way in because of the tires splashing it all around.
check under the car for any missing or half-ass'd plugs hanging.
im not driving my car at all .it just stays and when it rains i see water commin out of the speaker grill. The water is not getting inside the door, I see only water run down marks from speaker. It drips the where the gas door and trunk release levels are and goes underneath the carpet and stays there....:ohdamn:
