Water Injection Setup Help.
TommyDSM
241
8
Aug 2, 2003
Somewhere, New York
I'm building my own Water Injection Setup. I have a brand new spare Walbro 255lph High Pressure Fuel Pump. Can I use that as a pump for my system?
NOPE!!
A fuel pump is not going to last very long pumping water, it's not made for that. Take a look at this Website http://www.turbomirage.com/water3.html
It has a list of parts you'll need and also part numbers for some items. Buy a shur-flo pump it is the way to go for a DIY project.
OR
You could just buy this setup from coolingmist http://www.coolingmist.com/detailpage.aspx?pid=045
I went with the Coolingmist Deluxe single stage kit with 150psi pump and it has worked perfectly for the last 3 month since install...
Hope this helps..
