91-gsx
- 932
- 11
- Mar 31, 2005
San Jose,
California
i have been reading about built engines that people have on this site. and one of the main reasons for building an engine is that it can take more heat without melting pistons, or other parts. on pump gas the best way to make more power is to raise boost and to lower timing. but a stock engine cannot take too low of timing because it will heat up too much and you might end up melting parts. now the idea i had was to use water injection along with lower timing and lot of boost to make a lot of power on the stock internals without melting them. most people like water injection because it allows you to run more timing and a bit more boost, but boost is what makes more power. so i was thinking of running low timing and high boost but use the water injection to cool the cylinders wich should allow me to get away with the increased cylinder temps from low timing. alcohol works well to cool everything in general, but i do not have that readily available all the time. plus water cools the head and cylinders a lot better, but alcohol can get your intake temps below ambient.
this is just an idea, tell me what you think. it might also help those of you with an injection system now.
later
later
