Water Injection Kit - Need help w/ nozzles
Gabe92RTTT
92
Feb 7, 2004
Albuquerque, New Mexico
Hey all,
I ordered all the parts and put together my "home made" water injection kit with advice from turbomirage.com for my Dodge Stealth 6g72. I have a 60psi pump, water selenoid and it is activated by a hobbs pressure switch. Everything works and functions correctly as I tested it last night off the car with an air compressor.
The only thing I am concerned about is how much water this thing is spraying! I am using the 6.32 GPH @ 40psi nozzle that was recommended on turbomirage.com for the 4G63 engine and it sprays a bunch of water. After about 30 seconds or so a small bucket had about 1 inch of water in it! Is this normal? Should I order a smaller nozzle? What is a typical nozzle size for a WI kit?
Thanks!
Gabe
