wat do u guys think i will run with this set up?
Focusonme13
60
Dec 18, 2003
Lyndhurst, New Jersey
92 awd AUTOMATIC
stock trans with 40k miles on it, maybe getting a shift kit- i hope
Big 16g, ported maybe clipped, not sure yet
2g ported exhaust manifold
2.5 inch Downpipe/testpipe to 2.5 inch exhaust with a flow master muffler, right before the driver side rear wheel
3 inch hard intake with K&N free mods
450 cc injectors/ manual trans ECU
FMIC with custom piping
greddy type S BOV
MBC set at 15 lbs
wat do u guys think??.....and by the end of the summer i should have 2g mas, 550 injectors, 190 fuel pump/rewire kit
how much will my 1/4 time drop with this also.....let me know, thanx guys
this is wat it looks like now, it just looks like a 12 second car!!! hahaha
wasnt that car on ebay? I think i saw it there, If it was I was thinking about guying it and fixing it up also. but I think your set up is going to be very nice. sounds like its going to be very fast also
I would guess a low 13 with a bit of tuning and that shift kit would greatly help.
Ya I have the exact same set up but with a supra side mount you'll probably run high 13's until you get the 550's and 2g mas BUT, YOU STILL NEED AN SAFC. (that had to be caps) I thought the car was fast before I got it now it just screams. Oh and after the 550's you will probably get down to mid to low 13's untill you get it tuned then mid 12's shouldn't be a problem.
PS Port that O2 housing also I was getting boost spikes until I did mine now it's just smooth 18 psi all the way to redline
