Waste gate actuator?
92dsmgst
92
Dec 9, 2008
Streetsboro, Ohio
my 92 gst wont hold full boost it just bleeds off real quick. i did a BLT and only had pressure escape my dipstick tube.....i got a new PCV valve and the problem still is there. I did a compression check and got 135psi all the way acrossed....Could my wastegate be cuasing this problem? thanks
OO ya for sure. Pre turbo exhaust leaks and wastegate problems can easily drastically change the way you boost...
All i have is a greddy bov and a buschur cat back...can i get an aftermarket wastegate accuator? mitsubishi discontinued them.....if i can could some one show me which one will directly bolt on to my 92 eclipse gst automatic? also i was wondering it it could cause blow by oil in my intercooler pipes?
oil in your intercooler pipes is there alot? sounds like blown turbo seals. leaking oil into the compressor housing. unless is coming from the intake, in which case you have a problem their. either way you need to look into it asap. could be something small.
Spelling in your thread title corrected. Please take the time to learn, understand, and follow the rules.
