evogst97
- 80
- 0
- Feb 14, 2007
Los Molinos,
California
Well both me and my brother have been in the dsm game for a year or so and working on our cars together. We've gone through a lot of crap but the fun of having this car makes up for it. Anyways we both were having some problems and decided to do some headwork at the same time. He's been getting most of his info off this forum and I figured I'd join too.
Well anyways heres my current situation. My turbo blew so I put an Evo III in. Then we did the head work due to some oil being burnt or so we think.
Right now I have two main problems.
1:
White smoke comes out the exhaust at idle. I havent gotten to drive it much to see if it comes out while driving. The coolant was recently filled and now the reservoir is a little low but I'm not sure if it has to do with it being lost or just being filled throughout the system. It seems like the oil is a little low but thats hard to tell also because of the same reason. I've checked the PCV valve and it works fine(only blows air through one side). No boost leaks from when I checked from the turbo but I still need to check from the throttle body. Also I will check the intercooler piping for oil asap. Not Head related or valve seals or anything. Just had them all done and the compression is near perfect. My brothers having similar problems but we both cant't figure it out.
2:
Idle is lumpy...like it skips a beat. Timing is good and no boost/vacuum leaks. The vacuum does read 10-11 hg where it used to read 20 before the cylinder head job. Will check the BISS oring soon as well as maybe clean the throttle body but 10 hg's difference seems like a lot. My mbc seems to be working well and have never had problems with it.
Any help on either of these problems would be great. Feel free to pm me or just leave a reply. It's cool to finally be part of the online dsm community.
1:
2:
Alternator fuses are good but I'll see if I see anything in the wiring. As for the torquing of the head we did a compression test about a week ago and It was the same.
