Walbro Fuel Pump Rumor (?)
killab443 said:
I just got a used 255 hp off of a guy online. Its for a 1g awd, what do I need to get it workin rite...?
You need the install kit . There is a cap that goes the out put ,along with a new o-ring . On the intake side you will need a filter and liter retainer . For mounting you will need a new walbro rubber adapter to hold the new pump in the bracket . Last but not least a zip tie to hold it all in place , some people dont use the rubber foam sleave that goes around the pump . I think it is needed to secure the pump properly with a zip tie so it is not sliding around . Install kit needed :thumb:
