walbro 255 and fuel pressure reg.
talontedtsi1995
140
Sep 14, 2005
reading, Pennsylvania
alright.. i know there have been previous post but I still have to found what I am looking for, I have a 95 talon tsi with t-28 turbo and 3 inch turbo back exhaust, I bought a walbro 255lp fuel pump and put it in about a month or two ago and its been running fine, Is it safe to not have a fuel pressure regulator? I want to get one either way and I have been looking on extreampss.com web site, now, do i need to buy the air fuel pressure regulator, install kit, and gauge to have it work? from what i can see it will well over 275..does that sound right or would that be spending too much..thanks
I have that AFPR and I love it. If you order it, order an liquid fuel pressure gauge from summit and run it right on there. Goodluck
yea..says its out of stock now tho..but that looks good.. it will set me up for the 1:1 ratio?
Hmm, I guess they are out of stock. I couldn't find anyone else who sells it. The next one up is $45 more... and it comes with an Aeromotive AFPR, so you know you are getting a good quality product!
DSM - AEROMOTIVE FUEL PRESSURE REGULATOR INSTALL KIT
SPECIAL $219.00
Aeromotive Fuel Pressure Regulator - #13105
- 6 Full Flow Fittings
1- Carbon Face Gauge 0 to 100 psi
1-XRP Straight Fitting
2 - XRP 90 Degree Fittings
1- Fuel Adapter for stock DSM Fuel Rail
2 Ft. High Pressure Hose - Black or Blue
Regularly: $239 SPECIAL: $219
http://www.fuelinjectorclinic.com/cart/fuel_p_regulator_kits.htm
What about the importevolution kit? And fullthrottle sells that bolt on fpr. I think import evolution has it too.
And how did you NOT find anything on a 255 and afpr? Sounds like you didn't search very hard, this has been discussed OVER and over.
The kits you can get from import evolution should cost you more than 200 unless you get ssb line.
