VR-4 C51PH or C50PH TRANSAXLE IN 92 TALON.
madmader
124
Apr 28, 2005
Grants Pass, Oregon
Anyone on here tell me what i need to drop a VR4 C51PH or C50PH TRANSAXLE and t-case In a 92 talon? Will i need diffrent shift cables? Other drive line parts.. Or is it just a straight up bolt on?
Talon has a 4 bolt rear, will the drive ratios be the same in the transaxle and t-case to match???
i think it was VFAQ.com that had the ratio's and there the same.
i recently just purchased a c 51ph trans and cables also. it was in a 92 tsi, i didnt purchase the t case didnt even know what trans it was till i got it the guy i bought it from knew nothing about it. should i buy the t case or us a regular dsm 22 spline t case. the trans should just go right in and shift fine if i replace the cables and put in my 90 shifter assembly?
  • Wanted 6 bolt NT water pipe
    • chrisman287
