Volts not changing?
bcjjones
509
6
Nov 3, 2011
Austin, Texas
Trying to adjust my TPS but it seems like the voltage doesn't change. From the red/green wire to the black green it reads 4.97 volts. I know its supposed to be 5v and when trying to adjust it the voltage never changes. I can push the TPS from one side to the other but it will not change at all. Sign of a bad TPS? I also checked from the white/green to the red/green and got a steady 1v. Which I know its supposed to be from. 48 to. 52 but that will not change either. Anyone have any idea?
Anyone?
The way we describe the wire colors are main color/stripe color.
The Green/Black goes to TPS pin 4 and is Ground.
The Green/Red goes to TPS pin 1 and is the +5v sensor power from the ECU (4.97v is close enough)
The Green/White goes to TPS pin 2 and is the TPS output voltage. On the car it should vary from ~0.5v to ~5.0v as the throttle is turned when measuring between it and ground (between the G/W and G/B wires)
Try measuring again using the correct wires.
