For Sale VEI gauges
turbosax2
Moderator
4,482
673
Nov 19, 2006
Mechanicsburg, Pennsylvania
*Gauge bezel not included - only the gauges and sensors*
$315
The price includes shipping to CONUS and PayPal fees.
I'm selling three VEI gauges. All are Ice Blue display color, silver bezels, and units are F/PSI. They have programmable flashing alerts and adjustable day/night brightness settings. They're easy to read even while racing and because they're dual function, they save a lot of space since you're getting six gauges for the space of three.
The only reason I'm selling these is because I switched setups and now have a digital dash. I used Deutsch connectors with this setup so most of the wires will still have the pins attached. You can either use these or cut them off.
1. D1-Series Dual Oil Pressure & Oil Temperature Monitor (D1-OPP-OTF-MB). The temperature sensor is included but you will have to provide your own 100psi oil pressure sender. These are $70 from VEI or any 0.5-4.5V sender will work.
2. D1-Series Dual Oil Temperature & Water Temperature Monitor (D1-OTF-WTF-MB). Comes with both temperature senders. One is brand new since I planned to use it for transmission temperature but never got around to it.
3. D1 Series Dual-Display gauge: Vacuum-boost & Wideband Air-fuel Ratio Display (D1-BOP-WBA-MB). The boost sensor is included but you have to supply your own wideband signal to the gauge (any wideband works).
