Valve Stem seals and Timing gone wrong??
cristian209
Jan 13, 2011
atwater, California
:hmm: ok so my car has been smoking and burning oil so I replaced the Valve stem seals with the head on the block with the EuroXport tool and all went good and sonce my timing was a little off and the cams were coming off anyways, so also did timing using Vfaq and some threads on this site. Once finished we fired her up and something is not right:cry: at first the engine vibrated then seems to choke and shuts off.:ohdamn: Idles funny but atleast theres no more blue smoke out the exhaust:thumb: This noob would really apreciate some help guys:sosad:
Have you driven the car at all or enough to throw a cel? Maybe there's a chance that some vacuum lines are not correctly hooked up. You could also check the timing if that would make you feel better about that part.
The car isnt even drivable up to now and even though the battery was disconected it did show a CEL after trying to turn it on twice
I'm pretty sure we got the timing marks right, so maybe the CAS... What should I check for on the CAS??
