valve cover leaks!!!
jbark
115
May 11, 2008
Reading, Pennsylvania
so i replaced my gasket on the valve cover due to a leak and it still leaks. do i need a new valve cover or should i get some sealent. its in the typical half moon area. also not all my bolts tighten as i think they may be stripped. is there a way to get them to tighten without getting a new head?
-jeremy
One would think you should investigate why the bolts wont tighten before you wonder why it leaks. If you stripped the head out you could heli-coil it.
