Vacuum plumbing and new parts
BlackbirdOfPrey
435
Dec 4, 2003
Shiloh,
I have a question or two about plumbing and some new parts I recieved. I ordered Fp's 4inch intake with NO inlet ports (straight pipe with filter, no vacuum fittings) and I was wondering the correct way to plumb all of the things comming from the valve cover so as to avoid air leaks and oil leaks. BTW I am using a Tial BOV venting to atmosphere if that helps (along with a 3.5in GM MAS).
1. Do I need to replace the PCV valve with an NPT fitting and just plug it and put a breather filter on the valve cover, or would this cause problems? (looking for the RIGHT way to do it)
2. I have my MBC going from the wastegate acctuator to the LICP, but my FMIC kit has no vacuum port on the lower pipe, what is the best way to reroute the MBC lines, I know I will leave one port plugged into the wastegate actuator, but where should the other one go? To the top of the BOV?
3. Because I am not recconecting the charcoal canister line should that just be removed as well? (I don't have emissions requirements so that isn't an issue), if so what else needs to be plugged?
